4l60 vs 4l80
Old Mar 10, 2013 | 07:49 PM
98cobrakiller's Avatar
Default 4l60 vs 4l80
looking to upgrade my trans is it worth the change from a l60 to l80.
Old Mar 10, 2013 | 09:18 PM
Bullitt117's Avatar
I'm not an expert on the specific benefits of the 4l80e over the 4l60e, but I know the 4l80e is a hell of a lot stronger. but the gearing in the 80 isn't as aggressive and its heavier than a 4l60e.
Old Mar 10, 2013 | 09:23 PM
Burken01's Avatar
Everything is smaller on the 60e, when your making big power you need the stronger transmission... IMO
Also the extra weight of the 80e makes up for itself because you can run more power and launch hard off of the transbrake if you have one..
the 4l60e has its time and place depending on your goals...
Old Mar 10, 2013 | 09:27 PM
Burken01's Avatar
550+ hp and alot of transmission builders recomend a th400 or 4l80e...
There are some built 4l60's handling big power too though, the only downside to the 4l80e is swapping it into a fbody and rewiring and retune , banging out the trans tunnell etc...
Old Mar 10, 2013 | 09:31 PM
Blackbird-WS6's Avatar
all depends on your goals and needs weather its worth the swap or not
Old Mar 10, 2013 | 09:50 PM
Blackpanther99's Avatar
What is your HP/setup? Will you do a lot of racing?
I agree with BURKEN01.
Old Mar 10, 2013 | 10:43 PM
Jake's Performance's Avatar
It really depends on the power level and the power level goal.
I see no reason to swap over to a 4L80E below the 500 RWHP level unless you are going to up the power later.
I'm not one to push the 4L60E unit but it has it's place and being the OEM unit in many GM vehicles, there are times when it's the best unit to use, even when you may be pushing it's limits.
Once you eclipse the 500-550 RWHP level, the 4L80E should be a consideration.
Old Mar 11, 2013 | 01:33 AM
02sleeperz28's Avatar
I think you should check out RPM's level 7 4L60E package. This is what I have. I've had levels 5-7 and have not had any issues from any of them. Cross fingers for this season! LOL
Old Mar 11, 2013 | 06:27 AM
well as of right now its a bolt on car nothing major mostly exhaust. trying to keep the gas mileage ucause its my dd. but when may gets here im pulling it off the road for good. i want a solid transmission thats going to take the punishment when im at the track with is 5-8 times a year for test and tunes, and when im running hondas the street. i have a 408ci from texas speed on the engine stand now. so im hoping after the 4k stall and the 9in rear im around 450rwhp on motor. maybe later a small 75 or 100 shot
Old Mar 11, 2013 | 09:13 AM
Check out RPM's website: http://www.rpmtransmissions.com/
