Scangauge 2 Trans temp
Old Mar 23, 2013 | 11:36 AM
Black01Bird's Avatar
Default Scangauge 2 Trans temp
Wasnt real sure where to ask this, but since its about trans temp i guess this is as good of a place as any.
So i bought a scangauge 2 after hearing what all it could do and plus i needed a trans temp gauge anyways, so my question is does anyone know the command that i need to make it read the trans temp from an 01 trans am with the 4l60e?
Ive read that the older scan gauges could not read trans temp, but from what ive read (i hope so) is that this one can?
Thanks for any help guys!
Old Mar 23, 2013 | 01:21 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
ScanGaugeII needs to go into the Xgauge mode and then enter some codes. I haven't used mine yet in the Xgauge mode yet,but the instruction book/manual tells how. I only use mine for intake temp.coolant temp,rpm,mpg, & loop.
Old Mar 23, 2013 | 01:28 PM
Yeah, i figured it out, wasnt putting the 01 at the end of the code lol. This can be removed.
