strengthen 4l60e
At a minimum, I would recommend installing a .490/.500 boost valve. The Sonnax 4l60E-LS1 would be a good choice. This is increase minimum and maximum line pressure, give you firmer shifts and generally extend the life of the clutched.
If you are comfortable removing the valve body, I would recommend the Transgo HD2 shift kit; it includes a .500 boost valve. In addition to the shift kit, you may need/want a new separator plate (Transgo Universal is about $25) and Sonnax 10000-8 torlon check ***** (partly in case you lose one).
