Stall install
Old Apr 22, 2004 | 12:41 PM
98 T/A raptor's Avatar
Default Stall install
Is there any thing important I have to do or schould know before it is to late?
Are there any gaskets I need to replace?
Old Apr 22, 2004 | 04:16 PM
Hyper Chick's Avatar
The only gasket I replaced was the pan gasket because I changed my filter while I was at it. Some recommend changing an O-ring, I think it's where the converter neck plugs into, but I didn't because I didn't find out about it until after my converter was already changed.
Old Apr 22, 2004 | 06:56 PM
Cheatin' Chad's Avatar
Take a look at some of the other TC install threads that have been posted
https://ls1tech.com/forums/showthrea...verter+install
I didn't replace any gaskets or seals when I did mine. I checked everything out and it looked ok. So I moved on.
good luck!
