one cooler or two?
Old Apr 22, 2004 | 09:16 PM
heyitsTaJay's Avatar
Default one cooler or two?
which is better.........one trans cooler or two? i have a 19k gettin ready to go in, but thought if i can find another y not?
J
Old Apr 22, 2004 | 10:02 PM
Ttt....
Old Apr 22, 2004 | 10:41 PM
2001-WS6's Avatar
You can run two but you probably wont' need the second one. I run a 19000 and a 24000 to keep things cool because the Tranny Blanket does block air flow and hold heat when you're crusing in the lovely Michigan Construction traffic.
At your combo I would simply recommend spending the extra money on a Tranny Temp guage so that you can monitor what's going on and have the peace of mind that the guage offers.
Rick
Old Apr 23, 2004 | 06:32 AM
boomcase's Avatar
I run the factory cooler and a aftermarket cooler.
Old Apr 24, 2004 | 02:11 PM
supersp0rt's Avatar
i was going to step up and go big single...but i talked to 2001-ws6 about his setup and decided to give it a whirl. so far im seeing a 15F relief. i guess it depends on the temps youre seeing now.
Old Apr 24, 2004 | 02:43 PM
Zo6Killer's Avatar
On my '67 I completely bypassed the radiator cooler, and I'll tell you why: the transmission fluid has to be "cooled" by a heat exchanger that usually runs 180-200 degrees. I looped the lines between two seperate coolers, and installed a Griffin aluminum radiator with no provisions for an oil cooler. The fluid goes into one Derale cooler (19000) and then passes to a B&M 24000 cooler and then back to the transmission. I used all Russell braided stainless lines (-6) and it keeps the tranny between 180-195 AT ALL TIMES! Works like a champ.
