Converter Stall?????
Old Apr 26, 2013 | 10:19 AM
dalooboyz's Avatar
Default Converter Stall?????
Building an 84 Camaro 5.3/4l60e swap. Headers, and the Torquer V2 cam from texas speed.232/234 and 595/598 lsa 112. was wondering if anyone could give me a torque converter stall that would work with it. I dnt want to spend a ton of money and im not looking to make a drag strip car. mainly a cruiser with some launch from a street light. any input would be awesome....thank you
Old Apr 26, 2013 | 10:54 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Dalooboyz,We offer 2 different converters that would work with that combo. I would recomend the SRLS0086 3600 stall for DD applications. This converter will eliminate any dead spots and will reduce ets by 4 tenths. The other option is the SB3200 which will reduce ets by 2-3 tenths. This converter is much more economical.
http://shop.fticonverters.com/GM-SB-...erters_c55.htm
http://shop.fticonverters.com/LS-Ser...-4L65E_c64.htm
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Apr 26, 2013 | 04:24 PM
Circle-D's Avatar
I agree with FTI, you could use the 278mm option and save some money. But that cam would really like a 245mm, the performance would be worth it in my opinion. If you want to give me a call at the shop or you can fill out an "Ask Chris" form with your full specs and we can discuss your options.
Chris
