PerformaBuild lvl2 users..
Old Jun 3, 2013 | 11:15 AM
Dynamic396's Avatar
Originally Posted by PaSteLaSo4U
is the 2-3 shift at WOT firmer than the stock 4l60e or does that lazy shift its part of the 4l60e character? Just wondering if I should expect an improvement there...
Yes, you should get completely different shift characteristics on every shift. How much of a difference depends upon how whoever builds it sets it up...
Old Jun 3, 2013 | 05:48 PM
mrvedit's Avatar
Moderator
The stock setup uses a lot of clearance (.050-075) in the 3-4 clutch and a relatively small feed hole which results in a very gradual shift. I don't know the exact specs of any sponsor's builds (they are hard-earned trade secrets), but I'm confident the clearance is much less and the feed hole is much larger, giving you a fast and noticeable shift. A faster shift (within reason) actually produces less heat and wears the clutches less.
Old Jun 3, 2013 | 06:03 PM
Chaos07's Avatar
Performabuilt is pretty awesome. My lvl 2 lasted a good year with an improperly installed converter. Shows you how tough it is. But lol it got trashed when it finally gave out. Already going to order me another and get it installed right and I'm sure it will last for years
Dynamic396's Avatar
Yes, a tighter 3-4 stack helps, but even more critical is a proper 2nd servo setup. This is crucial to a solid 2-3 shift.
And, yes, orifice sizing is a bit of a secret, but what size to use in what setup depends upon so many other factors that inexperienced "builders" still won't know what to do with them. I use .093" and .110" a lot...
Old Jun 3, 2013 | 06:50 PM
mrvedit's Avatar
Moderator
Originally Posted by Chaos07
Performabuilt is the ****. My lvl 2 lasted a good year with an improperly installed converter. Shows you how tough it is. But lol it got trashed when it finally gave out. Already going to order me another and get it installed right and I'm sure it will last for years
Since you seem to be happy with Performabuilt, you may want to chose a different word in your first sentence. I first thought you were being critical.
Old Jun 3, 2013 | 06:57 PM
Chaos07's Avatar
Fixed
Old Jun 22, 2013 | 08:46 AM
PaSteLaSo4U's Avatar
Just paid off and awaiting delivery of my new PB lvl2, can't wait. Any pointers for the swap or it should just be a breeze?
Do you guys usually bypass stock radiator cooler? when racing you slap her to D or 3rd?
Old Jun 22, 2013 | 11:57 AM
Chaos07's Avatar
just paid mine off too....cant wait to be driving again
Old Jun 27, 2013 | 06:07 PM
Nice, received yours yet? i'm waiting on mine.
Old Jul 16, 2013 | 06:52 PM
Just got the transmission, now i gotta debate wether i should leave the stock rad cooler in conjuction with the b&m in front of rad or bypass the stocker?? if so, how hard will it be?
I'm assuming just disconnecting hoses going to rad and connecting them together? is that it? thanks
Old Aug 11, 2017 | 11:27 PM
fastsspr's Avatar
Another Performabuild LV2 for the street. I going to install mine with a Yank stall this next Tuesday!
