Which trans mount?
Old Jun 25, 2013 | 08:58 PM
Jet49's Avatar
Default Which trans mount?
So I am swapping a 99 trans am ls1 auto into a 95 z28.
I noticed that the trans mount from the 99 is broken so I went to autozone to buy a new one.
The one for the 99 was $74 and the one for a 95 Camaro was $13.
I ended up buying the lt1 trans mount.
Will this still fit perfectly even though it looks different from the ls1 trans mount? Or should I just pay the $70 for the ls1 mount?
The part number was 2817 for the lt1 mount.
Old Jun 25, 2013 | 10:00 PM
skopers3's Avatar
Not sure on your specific issue, but I can tell you NAPA had the correct part number for my 2000 and it was less than $20.
Old Jun 25, 2013 | 10:03 PM
skopers3's Avatar
It's part number 620-1261.
Old Jun 26, 2013 | 12:21 AM
Jet49's Avatar
So the one from NAPA looks like this:
And the 99 Trans Am one looks like this from Autozone:
And the LT1 Auto version I bought from autozone looks like this:
Autozone has two 6 speed versions with one looking like the NAPA one.
And by looking up the 99 Trans am through NAPA I get the same ls1 version that autozone has but for $82.
Now I am really confused lol. I would think that the LT1 version would work, since I believe all 4L60E's have the same dimensions, etc.
Old Jun 26, 2013 | 08:25 PM
mrvedit's Avatar
Moderator
I suspect you are overthinking this - any of those will work.
IIRC I am currently using a TH400 mount spec'd to a 1970 Big Block.
