2pc 4l60e with AWD 4472 transfer case
Old Jun 28, 2013 | 03:01 AM
bmfrc's Avatar
Default 2pc 4l60e with AWD 4472 transfer case
Im building an AWD s10 with an ls6. I want to run a late style 2pc 4l60e mated to the AWD transfer case same as Typhoon.
I currently have the AWD transfer case still mounted to the 700r4 I bought from a Bravada.
So the 2pc 4l60 has a 6 bolt tail housing, different from the 4 bolt housing on the 700r4.
2 questions:
*is there a tailhousing adapter for the 6 bolt trans to the 4472 transfer case from another vehicle that will work???
*will the output shaft from the 700r4 work in the 2pc 4l60 case, regardless of the tail adapter for the transfer case, say I had one made.... worst comes to worst, which it usually does...
