4l60e limp mode after engine swap
Old Jul 18, 2013 | 06:35 PM
mrvedit's Avatar
Moderator
A 3500 converter is fine with a stock engine/trans. Absolutely - lots of members here have such a combo.
However a bad converter might give such symptoms; I don't have any experience with bad converters; hopefully others can post their knowledge and experience.
Old Jul 18, 2013 | 10:26 PM
RevGTO's Avatar
Pontiacerator
Local shops will freak out when you tell them you have 3500 stall converter. They mostly have no idea of LS converter technology and what makes these cars run.
What brand is your converter? Did you buy it new or used?
Old Jul 19, 2013 | 11:42 AM
Y87bird00's Avatar
It's a circle d, it was used. I'm probably going to drop the trans and put in a stock one
Old Jul 19, 2013 | 11:57 AM
Roarin_8's Avatar
You're in Texas, there are many LS shops in that state. Stop going to that trans place, they have no idea about LS setups.
Old Jul 19, 2013 | 12:09 PM
Roarin_8's Avatar
Just to name 2 even though they are in Houston, LMR and G Force motorsports. Try contacting them and maybe they can refer someone closer to your area.
Old Jul 19, 2013 | 01:12 PM
Y87bird00's Avatar
Thanks for the names. I've called many shops and a few big name builders but they can't help without seeing the car.
I just got the car dropped back off at my house. What's wierd is the tow truck driver mentioned I had no reverse. But the forwards were fine. Every time I got in it, reverse was strong but I didn't have forwards... I still don't think this is converter related. I did just pick up a cheap stock one tho just in case.
Old Jul 19, 2013 | 02:01 PM
Y87bird00's Avatar
Got in the car, had no movement. Added fluid, starts in 1st and reverse perfect. Just doesnt shift out of first..thoughts? I really don't think it's the converter
Old Jul 21, 2013 | 12:48 PM
Y87bird00's Avatar
No speedo, must be VSS. Hopefully all is good after that!
Old Jul 22, 2013 | 11:35 AM
Y87bird00's Avatar
Found a cut wire on the VSS. Stupid shop can't check fluid levels and basic electrical connections. Car runs awesome!
Old Jul 22, 2013 | 02:33 PM
Roarin_8's Avatar
Awesome!!! Now stay away from that shop
Old Jul 22, 2013 | 04:15 PM
Y87bird00's Avatar
Deffinitely. Trans slips at anything over half throttle, so ill need to build a new one up soon. As long as I am able to drive around! Love the sound of the v8
Old Jul 22, 2013 | 04:19 PM
  #32
Roarin_8's Avatar
You and me both
Old Jul 22, 2013 | 04:27 PM
  #33
Roarin_8's Avatar
Get a built 4L80E and be done with it.
