What could cause this?
Whenever my car goes to shift from second gear to third at WOT there is a hesitation during the shift. It's like the band is being released too early or the 3-4 clutch pack is being engaged too late because there is an rpm "flare up" during the shift. The car will reach the top of second gear, bang the rev limiter a few times, then drop into third. It shifts hard into 3rd gear when the 3-4 clutch pack engages so I don't think it's slipping. It's like the shift is all screwed up or something. This is a pro yank 4L60E btw...
My 3-4 clutch pack burned up a while ago and I replaced it just last week. I know that I didn't cause this problem working working on the transmission because it did this before. I thought it was simply a matter of the 2-3 shift point being set at too high of a speed, but it's not. I've tried everything with LS1 edit and nothing helps.
I can't figure out what the problem is.
its a param on edit/hptuners
