Good or bad or don't matter
Old Jul 17, 2013 | 06:44 AM
sgtrgpfdps's Avatar
Default Good or bad or don't matter
I have a bad habit of flicking my trans from drive to net. shen I coming to a stop. I just coast to the stop and put back in drive.The car can be moving when I put it back in drive. I have t/a withs tock auto. Any opinions .
Old Jul 17, 2013 | 06:51 AM
SSellers's Avatar
Shifting into gear when moving is bad at high speed so you have to assume there's at least a little extra wear at low speed but I don't know. You burn a little more fuel when coasting in neutral since it runs at idle pulsewidth instead of decel pulsewidth which can be as low as zero.
Old Jul 17, 2013 | 09:21 AM
mrvedit's Avatar
Moderator
Yes, with a stock or proper tune, the engine uses Zero fuel on deceleration down to about 1200 rpm. (Might be 1500 with a hot cam.)
Old Jul 18, 2013 | 02:09 PM
joecar's Avatar
You will wear the selector shaft and its seal.
Old Jul 18, 2013 | 02:55 PM
2000ultraZ1911's Avatar
Make sure you got ur foot off the gas and brake the habit.
Old Jul 19, 2013 | 06:47 AM
sgtrgpfdps's Avatar
Thanks, will keep in gear !
Old Jul 19, 2013 | 07:22 AM
vwdave's Avatar
I knew a guy who used to put the car in neutral when it was time to shift so people would think he was driving a stick.
That was the least of the weird things he would do.
