pre-maid trans lines or press fit lines
I have a real problem installing braided ss lines, and was wondering if any company had pre-maid lines? or if the press fit lines and fittings will work with trans fluid?
I was always hesitant to make my own braided lines until the saw the video from AN plumbing on how to cut an AN hose:
http://www.anplumbing.com/page/11
Basically go to Home Depot or Lowes, and buy an 1/8" or thicker piece of aluminum and a heavy duty chisel as seen in the video (about $12). No saw, no tape, no $100 hose cutter. It takes me barely 3 minutes to assemble a braided end for normal hose and 5 minutes for Teflon hose. Heck, if the hose is 1/2" too long, I redo it.
For trans coolers I recommend AN6 Teflon hose because it has a smaller outside diameter, can handle any fluid and easily handles the pressure.
