Question About Transmission Pan
These are the three most popular swaps for a trans pan:
1) Stock truck pan. It is still stamped steel but has a drain plug and carries 1qt of extra fluid
2) TCI cast aluminum deep pan. Drain plug, finned bottom and has 2qts of extra capacity. You can tell this one as it has TCI Automotive cast into the bottom front section of the pan
3) B&M cast aluminum deep pan. Drain plug, finned bottom and has 3qts of extra capacity. You can tell this one as it has B&M cast into the bottom middle of the pan
I believe there is even a pan out there that has 4qts of extra capacity I just can't remember it off the top of my head. So each of them will have different heights. Put it in the air and take a look at the pan and take some pics like 01ssreda4 suggested and it will help us to help you.
Here is the depth of a stock 4L60E pan for reference
