4L80 eating case bushings ?
Replaced drum,seals,bushings and T-washer/set up endplay.worked fine.300 miles later,drop pan,brass/copper flakes/chunks in the bottom. Same damn thing,new drum shot,rear bushing shot,T-washer gunked up with material. Rear seal good,output shaft,new, 300M custom fit.Luckily no case damage,shaft still looks good.Feed tube clean/clear,rear cooler line has extension to center support,I give ! This ***** getting expensive ! Any ideas from the trans gurus ? Here is a pic of the "new" bushing,Thrust washer after 3xx miles,street driving.
Sent the forward drum out to Omega ? in Cali to install a sleeve this time in the center,hope that helps a bit. Getting tired of buying new parts every time I drive the damn thing !
Was the trans COMPLETELY disassembled and all parts cleaned?
If not, do it the correct way and start over.
I wouldn't sleeve a forward drum. Just replace it. One more failure point and the area that wears on a forward drum isn't really a spot I would sleeve. It's not a smooth bore, it has a channel cut in it for oil flow.
Everybody thinks it's a simple cut and dry operation to rebuild a transmission. We spend 1.5-2 days per unit doing them and still have some take up a huge amount of time on the dyno to dial in the pressure or have to be torn back down. I dyno'd a 4L80E today with an odd clicking noise that has no visible cause on teardown.
Mechanical components must be lubricated with clean oil. If there is a blockage in the lube system or contamination, parts WILL fail, no matter what kind of unobtainium they are made of.
There is nothing wrong with the stock forward drum. You can make a steel sleeve if you wish but watch the oil flow. You could cut off the flow to the forward clutches.
What year core is this and what are you using for a rear cooler fitting?
mismatched rear geartrain components will foul up your day, and it's easy to do if you have different year model stuff laying around.
Post up pics of the rear of the center support. The drive tube, the intermediate shaft, the rear ring gear and bearing, output shaft, and sun gear.
VB is late model,short feed tube to rear,tube is clear,both directions.One possibility(maybe? ) Transbrake does NOT work,possible wrong separator plate causing lack of lubrication,or blocking a needed passageway ? I will ask Karl to look at that for me,maybe thats the issue ?
