4l60e problems after rebuild help
I only have reverse manual low and 2nd gear. It trys to slip in 3rd(barely) 4th is like neutral. Any ideas on what to check?
If Yes, then the forward sprag was installed upside down.
Or are you saying the car will start fine in [D4]/[OD] but will not shift into 3rd or 4th gear?
If Yes, then you have a major leak in the 3/4 clutch circuit. Did you air test the input drum both by itself and installed into the pump?
