4l60e build problems and (hopefully) solutions
Sorry to hear about your torn Stator rings. Did you use a resizer? You need to keep the resizer on until the last minute as the reverse rings rapidly expand.
Axekick: this is probably the most difficult bushing to replace; I use a dremel to carefully cut the old 95% through in two spots and then twist it out.
Perhaps the experts will correct me, but I use the plastic from a big pop bottle and two hose clamps to resize the stator rings. As I tighten the hose clamps snugly with a hex driver, I suspect I size the rings smaller than an official resizer. After installing the pump, I give it one day for the rings to open up before I start the engine and test the trans. (A pro builder will not have that 1-day luxury.)
I would suggest using the LB-1 because it has o-rings which seal it against leaks (caused by wear) and therefore give a more precise pressure.
I would
Otherwise you are correct - the ISS consists of a different input shaft/drum and pump. Also a different wiring harness. Yes, I think you should drop the truck pan and look for the ISS which is a wire going into the pump near the shift-shaft.
I also PM'ed you my cell # in case you want to discuss your options, but we should first know exactly what your truck has.
.035 does sound a bit much. Sonnax makes .010 washers to reduce it.
I think the output end play is related to input shaft end play and that should definitely be less than .035. Have you measured that?
You can purchase just the TCC solenoid and splice it in. $15. Or if you have the old harness, just cut it out, splice it into the new harness and use the o-ring from the new one if still OK. Of course, if you didn't already get a new harness, then this is a good time for that.
Then, to make matters worse. The wires on my starter were touching by the time I got it back in. When I went to hook the battery up the starter engaged. I figured, "that is a problem I can solve tonight", so I got t after it. When I started trying to get the wire right, the end of the cable broke off. I always knew if I worked on this thing enough times that that would happen. So no drivey tonight. Anyone know how to find a replacement cable for an 06 Tahoe? It has the little accessory box on the driver side of the engine. I'm assuming the cable goes from there to the starter.
I'm not discouraged although i am exhausted. I still think this thing is going to work. It's just not going to be very easy. Many lessons learned so far.
