which separator plate?
Old Sep 25, 2013 | 10:09 PM
Snap-On's Avatar
Default which separator plate?
I am building a 95 4l60 with PWM. It is going in a 94 fbody that does not have pwm. The transgo HD2 will be installed in the 95 trans. Would I use the 95 plate or the 94 plate?
Old Sep 26, 2013 | 08:25 AM
mrvedit's Avatar
Moderator
The early valve bodies from '93 through '96 have differences in their channels each year. '96 through '06 are all the same. Therefore, the separator plate has to match the valve body year.
Transgo has different separator plates for 93/94, 95 and 96/06.
It appears you will need part # 46-PLT-95 which is documented as "PWM Solenoid with 1st type 3-2 valve". The HD2 kit then replaces the PWM TCC valve with an on/off valve which should work fine with your '94 PCM.
Note: I'm not an expert, especially on these early years. If incorrect, hopefully an expert will correct me.
Old Sep 28, 2013 | 01:52 PM
Snap-On's Avatar
Great thank you!
