19,000 tranny cooler question
Old May 4, 2004 | 12:52 PM
Cokeroker's Avatar
Question 19,000 tranny cooler question
I installed a 19,000 B & M tranny cooler and the phantom autometer gauge pillar with trans temp. My question is this: what normal operating temp should my tranny be on the gauge? (approximately). I mean, what is considered a good (compared to stock) tranny temp?
james coker
Old May 4, 2004 | 02:46 PM
Ragtop 99's Avatar
My temp (as read by autotap) settles in around 160 on a normal day. You shouldn't see over 180* with your 160 T-stat set-up unless you are really flogging it hard.
Old May 4, 2004 | 03:18 PM
Graphite_WS6's Avatar
I have a 24,000 GVW B&M cooler on my car and my Trans Temp gauge has never gone over 180 even in this Texas heat. I usually run around 150-160. I also have an deep aluminum Transmission Oil pan though. But just as long as you don't go over 200, you should be fine.
Old May 4, 2004 | 06:31 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I like under 190F on the highway.
After a pass I was 'tween 190F and 210F.
If I did another pass I'd hit 220F.
I won't make a pass in a 4L60E if the temp is 220-225F.
Old May 4, 2004 | 06:50 PM
01Z0H6's Avatar
I have the same s/u you have. As mentioned above during "normal" everyday driving, mine runs @ 150-160....
Where did you mount your sending unit??
Mine is in the side of the trans pan. Works great!
Old May 5, 2004 | 01:49 AM
MadIceV8's Avatar
Customizing Director
Man I really need to install a trans temp gauge soon.
Old May 6, 2004 | 09:34 AM
Cokeroker's Avatar
a day of driving, dynoing and 3 passes at the track and my trans was still 155-165 deg the whole time.... the cooler works! (and the gauges are just pimp)
