Need help mating a 4L60e to an LS1
Old Oct 9, 2013 | 08:15 PM
blova00's Avatar
Default Need help mating a 4L60e to an LS1
I'm planning on mating a 4L60e with an LS1. Has anyone done this? Can anyone tell me what I will have to do to accomplish this? I' e heard that i will have to make mods to the computer??? Not exactly sure how to go about this. Any help is appreciated.
Old Oct 9, 2013 | 09:20 PM
Decadence75's Avatar
The 4L60E is what came with LS1 autos from the factory. If this is a stock F-Body LS1 then it should bolt right up assuming it still has the stock flexplate attached. And if it is an A4 f-body PCM then it should be ready to go, though some custom tuning of how the trans behaves would be a good idea.
Old Oct 9, 2013 | 10:47 PM
mrvedit's Avatar
Moderator
It just needs to be a '98 or later 4L60E for LS engines. These have a bolt hole in the 12 0'OClock position of the bell housing.
The computer is expecting a 4L60E, assuming the computer is setup for an automatic.
The input shaft and bell housing MUST look like this:
Old Oct 10, 2013 | 08:38 AM
blova00's Avatar
Sounds great, thanks for your help!
