4L80E Input speed sensor
Old Nov 7, 2013 | 11:51 PM
Bullitt117's Avatar
Default 4L80E Input speed sensor
I've used the search function but came up empty. I'm swapping a 4l80e into my 00 Trans am. How do I pin a input speed sensor into the stock PCM?
Old Nov 10, 2013 | 04:34 PM
Bullitt117's Avatar
anyone?
Old Nov 10, 2013 | 04:41 PM
Ferocity02's Avatar
Read through this: https://ls1tech.com/forums/automatic...0e-swap-4.html
Old Nov 12, 2013 | 09:41 PM
Bullitt117's Avatar
Nevermind, just figured out I don't need the input speed sensor.
Old Nov 13, 2013 | 12:15 PM
Mystery Bird's Avatar
I didn't use it on mine either. As far as PCM is concerned it doesn't exist.
Old Nov 13, 2013 | 01:00 PM
Ferocity02's Avatar
You need it if you're using an 80E segment in the tune. You don't need it if you're using the 60E segment with the relay(s) in the harness. At least that's how I understand it.
Old Nov 13, 2013 | 03:52 PM
slow67's Avatar
Gingervitis Addict
Correct!
