4l80e swap info (wiring)
Old Nov 17, 2013 | 11:08 PM
runsfromdacops's Avatar
Default 4l80e swap info (wiring)
hey guys im working on putting a 80e in to my 04 cts-v an im super lost on what i need to do to make the wiring aspect work.
i know that this car was never offered with a auto of any sort so i know there isnt a harness i can just plug and play made for the car
i know that this ecu was used in a few other cars that came with a auto.(like the trailblazer and a few others).i have pulled the tune on the ecu and it has the 80e as a option in the drop down menu. i have heard people say that it may need a segment swap to work but im not really sure what that is.
if i cant get the ecu to play nice ill just have to get the PCS -2000 to control the trans but id rather not spend the 700$ on it if i can avoid it
if i can get the ecu to control it what would i need to do for the wiring? would i just need to add some wires to the plug at the ecu? do i need a tcm also for the ecu to talk to?
just need some help making sens of all this crazy auto stuff haha
thanks for the help guys
-alex
Old Nov 19, 2013 | 10:13 AM
Cam72aro's Avatar
Is it the same ecu as a f body? The 411 ecu. If so yes, you need an adapter harness that will wire into the ecu. Spear tech sells a nice harness with instructions to wire it in. It is already terminated and labeled. I think it's around $200. The ecu will control the trans with a segment swap.
Old Nov 19, 2013 | 10:34 AM
It don't know what # the ecu is but I have read that the sa me ecu comes in trailblazers snd some other small trucks.
Will a segment swap cost me any more credits with hpt? My ecu already has the 2 bar custom os installed.
Could I just use a full truck harness in place of the custom one?
Old Nov 19, 2013 | 05:20 PM
erickcastillo95's Avatar
you could probably just get the connector from a doner 4l80 and repin your wires im not sure though
Old Nov 21, 2013 | 09:08 AM
slow67's Avatar
Gingervitis Addict
No, no extra cost on segment swap.
I'm 99% certain you can't use the entire truck harness, but you should be able to de-pin the transmission part of it, and add it to your existing harness.
This is assuminng its the earlier style of PCM (red/blue or red/green connectors).
All of this is assuming you can get a segment swap from HPTuners though (you will have to email them the tune). If you can get a 4L60E tune on it, I can make it run on a 4L60E tune also.
Old Dec 23, 2013 | 08:53 AM
Sarg's Avatar
Looking further into this, would the Speedo and all of that still work if it is segment swapped? I am assuming you would just need to add the aditional pins to the ecu and run the appropriateb wiring back tothe transmission.
