4L60E (2002) wiring harness - how to test?
Old Nov 20, 2013 | 06:01 PM
Dave Strasin's Avatar
Default 4L60E (2002) wiring harness - how to test?
Gents, can you tell me how to test the 7-prong connector that connects to the MLP Sensor/PRNDL switch? I just re-built my 4L60E and am preparing to re-install it in my 2002 GMC Yukon XL. As I was I went to re-connect the 7-prong connector, I noticed it was a little warped from the heat gun I had to use to disconnect it originally. I'd like to be able to test it to be certain it will work before I completely re-install the tranny. I suspect I'll need an ohm meter but not sure how to properly test it.
Thanks in advance!
Old Nov 27, 2013 | 02:00 PM
Wow...with all the backyard mechanics on this site, I thought for sure one of you would know how to do this...NO one?
Old Nov 27, 2013 | 02:17 PM
hevymetalg's Avatar
Do you mean the one coming from the computer or the one inside the pan/valve body ?
Old Nov 27, 2013 | 02:27 PM
mrvedit's Avatar
Moderator
I think he means the Park/Neutral safety switch combined with the Reverse switch for the reverse lights.
Sorry my car is a custom swap and all the wiring is my own.
Old Dec 17, 2013 | 02:11 PM
Exactly, gents. It's the black electronic box that sits on the drivers side of the 4L60E transmission. I'm having a difficult time getting the 4-pin and 7-pin harnesses re-connected, despite clearing away the hardened silicone from the original GM installation. I suspect there is silicone down inside the female connections and inside the harness on the switch itself (where the male pins are) so I would like to heat them up and make another go at removing more silicone, however; I'll need to be able to test the pins when I'm done to be sure I didn't damage anything with the heat gun, before I connect everything together again. I found a schematic, but no instructions for ohm-checking the pins/harnesses. Any help would be sincerely appreciated!
