4L60e
Old Nov 20, 2013 | 08:50 PM
cutlassmann's Avatar
Default 4L60e
What will it take to install a 4L60E in my Oldsmobile cutlass 350 olds engine and what extra will I Need.
Old Nov 20, 2013 | 10:50 PM
mrvedit's Avatar
Moderator
First an older style "LT1" 4L60E with a 298mm input shaft should be easier to adapt than the newer "LS" style with 300mm input shaft. This thread shows the pictures of the different input shafts:
https://ls1tech.com/forums/automatic...s1-4l60-e.html
The biggie is that you need an electronic controller which costs $500-$800.
You would likely find a 700R4 easier to install as no controller is needed and it should bolt right up. Others prefer the 200R4.
Old Nov 21, 2013 | 08:42 AM
fbody_brian's Avatar
You're going to need some kind of adapter for the BOP bolt pattern.
Old Nov 21, 2013 | 01:22 PM
mrvedit's Avatar
Moderator
Yes! Wow, I forgot that the BOP bolt pattern is different from Chevy.
