What's my problem? Trans or convertor?
Today I drained the E85 and put in 5 gallons of 87 to run the engine and get any E85 out of the injectors, fuel lines, etc.. Before it sits for the winter. I started it up and let it run to operating temps. Just for ***** and giggles I tried the gears. I went into all the gears, normally but it sounded like it was "clattering" then the clatter would go away. Finally, would not go into gear again.
First I was thinking it was the trans but now I am thinking maybe a broken flex plate or the convertor. I am not sure. Going to pull it but thought maybe someone new what it might be.
Its a power glide, a PTC 9.5" convertor. Flexplate is stock that I modified the holes for but have been running it like that for 2 years without issue. Lately it has felt as though it was dragging in gear. Especially reverse.
In the past we burned up a pump because I didn't space the convertor enough. This time I used two thin washers to space. Maybe it's too much of a gap now. I measured it to be a 1/4" gap which I thought was correct.
Let me know what you think.
Sometimes you can be in Park when it won't shift but the shifter is in park and if you rev it up it tries and moves the car just a little. Almost like your foot braking it but you aren't.
If you chip the planet set it is going to growl badly in neutral.
Low and reverse will bind and make noise
High should stay quiet for the most part
