Flexplate help
Old Dec 13, 2013 | 03:16 PM
1badeagle's Avatar
Default Flexplate help
I read the stickies and Im still a little confused. I have a 04 6.0 and im bolting a powerglide to it. I am going to run my ATI th350 convertor in this setup. What is the cheapest route to get this flexplate figured out. I know I can run a stock plate, but Id like a SFI rated one. Can anyone give me some part numbers? Jegs was unable to help me.
Old Dec 14, 2013 | 07:23 AM
forcd ind's Avatar
a power glide and 350 use diff converters
the TCI flywheel for a 4L80E that comes with flywheel, bolts, and spacer will work
Old Dec 14, 2013 | 08:07 AM
1badeagle's Avatar
This powerglide has a th350 input shift so it uses my th350 converter
Old Dec 14, 2013 | 11:16 AM
Circle-D's Avatar
Do you know what bolt pattern/s you have on the ATI converter? Or maybe post a picture?
Chris
Old Dec 14, 2013 | 03:13 PM
1badeagle's Avatar
It has both
Old Dec 15, 2013 | 12:08 PM
Circle-D's Avatar
OK, by both I assume you mean TH350 and TH400. So just about any LS SFI flexplate will work. You will probably need a pilot extension for the converter pilot to crank.
Chris
