Hawks 3rd Gen Poly Trans Mount ?.
Old Dec 26, 2013 | 06:58 PM
cgormanZ28's Avatar
Default Hawks 3rd Gen Poly Trans Mount ?.
First, I have a 2002 Camaro Z28 with the 4L60e trans, anybody installed
the Energy Suspension Trans mount or Torque Arm mount with any
obstructions, as far as bolt diameter through the crossmember! I heard
some machine work would be necessary to allow access of the
"energy suspension trans mount", in regards that the mounting bolt is
a larger diameter than the original? Just rumor?? Thanks.
Old Dec 28, 2013 | 02:58 PM
mrvedit's Avatar
Moderator
There are multiple threads here from people complaining about vibrations which turn out to be caused by Poly trans mounts. The vibrations/noises/clunks go away when they install a stock trans mount.
Disclaimer - I don't have personal experience with them on a Gen-4, but perhaps others can give you personal feedback.
Old Dec 28, 2013 | 03:30 PM
mrvedit's Avatar
Moderator
Just found a new post about poly mounts causing vibration.
See #53 in this thread:
https://ls1tech.com/forums/automatic...ckwards-3.html
Old Dec 28, 2013 | 06:42 PM
01ssreda4's Avatar
No need for poly, no need to deal with Hawks either. Lose/lose.
Old Jan 3, 2014 | 07:05 PM
cgormanZ28's Avatar
Thanks guys for the input! Word of advice, they don't line up with stock crossmembers, I ******* returned it. Garbage. Thanks again guys.
