Not your Average 4l60E build.
Old Jan 15, 2014 | 08:02 PM
baalic's Avatar
Default Not your Average 4l60E build.
What's not average about it?? I'm going to rebuild my transmission in my V6 Camaro as its toast, and I had a few questions, and yes, I've done searches, and such but its a lot more direct just to ask my questions and be done with it...
I plan on probably using this kit,
http://www.monstertransmission.com/4...l#.Utc8UfRDurs
It should be way overkill for my mostly stock V6 but allows a little room for if and when I decide to run the turbo build on the motor. And I figured I would go ahead and throw a new converter on it as well,
http://www.monstertransmission.com/4...l#.Utc8kvRDurs
And yes I know, again, this is probably overkill but that's not really the questions.
Questions are, these kits are intended for a much higher HP output then I will be running, in particular the LS1 type engines. Am I going to see any major compatibility issues with these, and while I am doing the transmisson, should I go ahead and try to find a used Aluminum drive shaft from a Z28/Formula ?
Internally all the parts should work or be the same for the v6-v8? And I know the stall is overkill but it should wake it up a little bit more then stock, especially if I end up swaping the rear gears to a 3.42 or 3.23 vs the 3.08 stock. I.E. will the stall fit my transmission as the bell housing is different?
Thanks in advance, guys.. Sorry I've been disappeared lately, I started getting really big into my new jeep so I have been on Jeep Garage
Cheers!
Old Jan 15, 2014 | 08:55 PM
mrvedit's Avatar
Moderator
I would avoid Monster Transmission anything, partly due to the bad BBB status they have. Also their kits are "old" with none of the desirable Sonnax parts. I have recommended TruTechTrans here many times and a bunch of members have bought their kits and been very happy with them. For example, you might consider this:
http://www.trutechtrans.com/4L60E-RB...-I-Basket.html
And ask them to add a set of new solenoids; I even think you will come out ahead pricewise.
Remember that your V6 4L60E is an "LT1" style with 298mm input shaft which will NOT bolt up directly to an LS engine. The converter you listed is an LS style converter which will not fit your trans.
Regardless, any $300 converter is crap. Instead consider a good $500 converter from sponsor Circle-D or Revmax. (Others sponsors Yank and FTI are more in the $750 range for even better converters which Circle-D and Revmax also sell for that price.)
Read this detailed thread:
https://ls1tech.com/forums/automatic...education.html
The difference between a 298mm (LT1) and 300mm (LS) style 4L60E will not matter to the rebuild kit, only the year of the trans is important.
Old Jan 15, 2014 | 09:03 PM
baalic's Avatar
The rebuild kit appears nice enough, I know a lot of people use the Monster Clutches and such, so I thought Monster would be a good brand to go on an actual rebuild. What about the Corvette 2nd Gear Servo ? Would this be something that came with that kit you listed as I didn't see it and would it matter if I left it out? Eventually the car will be Bracket Racing, and from my understanding it changes second gear a little bit??
Also what do I need to look for as far as Torq Converters? Do I need to search for a LT1 style torq converter to compensate for the input shaft? This is my first time to do a rebuild of this type on my own, and with a "newer" style transmission. It's not like the old TH350's of the past where all the parts were interchangeable basically haha.
Thanks for your input, these are the things I need to know before I dump a ton of money for something that is going to break and or not work ..
Old Jan 15, 2014 | 09:09 PM
baalic's Avatar
Also I know you advised against monster, but I am on a budget, and it IS a V6 not a V8 so the return on my investment is non exsistant but would this converter be the correct one? it still doesn't note 3.8 litre ? http://www.monstertransmission.com/4...l#.UtdM0_RDurs
*edit* or this one ? http://www.trutechtrans.com/4L60E-Co...UP-Basket.html
Old Jan 15, 2014 | 10:36 PM
mrvedit's Avatar
Moderator
I think those converters would likely fit; at $200 they will only give you stock performance.
A Corvette servo is at most a $15 part. With TruTechTrans simply call the owner (Jeff, who knows me) and explain what you want and he will put a custom kit together for you; there is no reason to order one of his "stock" kits as he is easy to reach and very knowledgeable.
Old Jan 15, 2014 | 11:31 PM
baalic's Avatar
pm me your name etc and I may do that and use you as a reference. I'm not looking for a straight drag racing TC, just something better then factory with more stall for bracket racing, and sporty street manners, after all, its still only a mostly stock v6 lol.
Old Jan 16, 2014 | 05:58 AM
LS-ONE_DAY's Avatar
FWIW Buddy had a Monster 700R4 that seemed like it would be nice but he didn't have the car that long after it was put in, anything in that trans family newer than a 700R4 (i.e. 4L60+) I'd avoid.
