Retune?
Old Jan 19, 2014 | 07:29 PM
Holloway5's Avatar
Default Retune?
I have a 2800 triple disc Vigilante stall converter, and it is much to small for the cam that I've put in(SI5 from speedinc). I plan on using Vigilantes warranty for a restall, and I'm bumping it up to a 4000. My question is would I need it to be retuned or not? I have searched the subject all over the place and have not found anything on the topic. If anyone could shed some light on this it would be much appreciated.
Old Jan 19, 2014 | 07:41 PM
mrvedit's Avatar
Moderator
The tune for a stall typically just disables some codes and reduces the misfire sensitivity. Once done, that will work fine with any stall or even the stock converter.
Old Jan 24, 2014 | 12:41 PM
Holloway5's Avatar
Thank you sir.
