Random Automatic Trans Question
Old Apr 9, 2014 | 02:55 PM
00cls1camaross's Avatar
Default Random Automatic Trans Question
Can an automatic transmission shift while the torque converter is locked up?
Old Apr 9, 2014 | 03:37 PM
Jake's Performance's Avatar
Yes. Not always the best idea, but it can do so.
Old Apr 9, 2014 | 04:36 PM
mrvedit's Avatar
Moderator
With the converter locked, the engine rpm has to drop rapidly at the shift. The engine (with converter mass) has a lot of momentum and since it can not drop instantaneously, something has "to give":
1. With luck, only the frictions in the trans will slip and wear out prematurely.
2. With less luck, a yoke, driveshaft, axle or trans part will break catastrophically.
Old Apr 10, 2014 | 03:03 PM
DREAMZ28's Avatar
Or wheel spin if on street tires. But I still wouldn't do it.
