4L60E not Shifting from 1st to 2nd
Old Apr 14, 2014 | 10:07 AM
Rolandt's Avatar
Default 4L60E not Shifting from 1st to 2nd
I have a 2000 camaro that just hit 111k at about 106k I had some mods done cam, heads set up, timing chain, ETC... And I put a Edge 3400 stall in a 4L60E A4. Now yesterday when I was in Drive at the Stop sign I went to drive off but it didn't want to shift into 2nd gear and my speedometer was reading 0mph when I was going it took awhile to shift, and also when I'm coming to stop but I let off the brakes there's a loud clunk any ideas on both problems, Thanks
Old Apr 14, 2014 | 12:50 PM
mantycarguy's Avatar
Vehicle uses speedometer input to command shift points. Its possible the trans is in backup mode which would command late and/or harsh shifts Check your connections at the vehicle speed sensor. If your connections are good you will need to replace the vss.
Old Apr 14, 2014 | 02:59 PM
mrvedit's Avatar
Moderator
Exactly right.
Check the VSS connector very carefully for corrosion. If the connections looks good, try replacing it.
Old Apr 14, 2014 | 03:42 PM
Rolandt's Avatar
and thats why it won't kick into the next gear?
Old Apr 14, 2014 | 03:46 PM
mrvedit's Avatar
Moderator
Yes, if the speedometer reads 0 mph the computer does not think the car is moving and therefore will never shift.
Old Apr 16, 2014 | 05:53 AM
Rolandt's Avatar
Okay that's what it seems to be doing haven't had much time to check it out, but I will replace that and see if it works I appreciate the help fellas
Old May 10, 2014 | 07:56 PM
Rolandt's Avatar
Update, I bought the VSS and put it in and it never did it again, thanks for the help guys I really appreciate it
