T56-4l80 swap
I recently purchased a stage 2 4l80 from jakes performance. Everything has went well except for the shifter cable brackets. It's an early core 80. If anyone has ran the early core 80 what cable and also what cable brackets did you use?
I run a 1995 4L80e, I used the stock f body 4l60e bracket and cable. I used a drill/grinder to elongate the bolt holes as the cable doesn't have enough length for proper adjustment until you slide the cable bracket. Its not pretty but it works.
