98 and 00 trannys?
Old May 15, 2004 | 11:21 PM
ls1perfcar?'s Avatar
Default 98 and 00 trannys?
Are the 98 and 00 model 4l60E transmissions the same because I put my friends yanks torque converter that came out of his '00 in my transmission because I had to drop in a new motor and everything started until i put it in drive and it was just like it was in neutral so im figurin the shafts on the tranny arent the same but im not sure. Sorry i didnt post this in automatic transmissions cause theres not much response in that forum. And is there a way i can pull the tranny out without havin to pull the intake off to get to that top bellhousing bolt?
Old May 16, 2004 | 07:18 PM
Can someone please help. I put my stock converter back in and its the same thing, I put it in gear and its like its just in neutral again and I hooked everything back up right. Only thing is we had the rear jacked up high and I put it in gear and revved it up alot of times and the wheels would rotate for like 10 seconds and stop...anybody have a clue whats wrong?
Old May 16, 2004 | 09:11 PM
cablebandit's Avatar
sounds like you didnt get the torque converter all the way on and messed up the front pump.
Old May 17, 2004 | 10:38 AM
No we put the torque converter all the way on and it still wont work...anybody have an idea whats wrong?
Old May 18, 2004 | 08:49 PM
Well we took out the line from the tranny to the cooler and turned on the car to see if it would spew out and it didnt so i figure the pump is bad, but we put in another 3 quarts of tranny fluid in it and i put it in reverse and it worked so i put it in drive it didnt work and then back in reverse then that didnt work....can someone help??????????????
