Shifting is a little funny Please Help
Old May 6, 2014 | 08:50 PM
Kevin_Ls1's Avatar
Default Shifting is a little funny Please Help
Ok Im having a problem... I bought a 99 Camaro Z28 off a freind of mine, the mods hes done to it is a "Yank 4,000 Stall Converter" and tune, Long tube Headers, MSD Wires, High Flow cats, SLP LoudMouth Exhaust. Now the issue im having pertains to the auto trasmission.. it runs fine except sometimes it feels like when im pulling out of my drive way, and im giving it gas its barely moving... I did a quick scan with the OB2 and it came up with a code for the VSS, could that be my issue or is it something else? Sorry Im new to this, any help is greatly appreciated. thank you
Old May 7, 2014 | 04:04 PM
mrvedit's Avatar
Moderator
The VSS is a critical part of the control of the trans. If you have a VSS code shifts will be wrong or won't happen at all. Is your speedometer working or intermittently?
We have had both reports of VSS sensors going bad, the connector on the VSS getting corroded and even the VSS wiring melting due to exhaust heat. Check the connector contacts first; a new VSS is less than $20.
