correct flexplate
Old May 13, 2014 | 09:09 AM
george88gta's Avatar
Default correct flexplate
Installing an 02 lq4 in my 02 Trans Am. I will be using the Trans Am 4l60E transmission. I have two flexplates. The one that came with the lq4 and the one that is on the ls1. Which flexplate should I use?
Old May 14, 2014 | 02:36 PM
The answer is use the new style ls1 flexplate and the shorter ls1 bolts. Remove teh spacer and install teh flexplate. Thanks to Chris at Circle D.
