P0740 (no symptoms)
This is an odd one- I've been reading up on it and I can't seem to get any solid definitive answers on it if you don't have symptoms. It seems that everyone who throws this code has noticiable transmission symptoms
I'm throwing P0740 in my 2002 ls1 camaro (stock 4L60e / stock stall) and I have no sympoms- my car shifts fine, 1, 2, 3, 4 and I am pretty sure it locks up as the rpms stay low enough? Although I am not 100% sure unless I scan it
Shifts aren't harsh, I do have a bit of a misfire, but Ive had that since last year and I am pretty sure it is from the back most spark plug that was the only one I couldnt get to to change (but will be sometime this summer)
Does anyone have any ideas of where I should start looking if I am not showing any symptoms other than the code (everytime I clear it and go for a short drive it comes back)
I just got back from a 6 hour road trip (each way) and she was beautiful- I reinstalled my wideband O2 sensor today and found out the sensor is fried, then right after I got this TCC code, I pulled the fuse out for the gauge just incase it is an electrical issue, but that doesnt seem to fix the problem.
I can scan it with hp tuners tonight- but what do I scan for? input/output shaft speed variation? what else? are there tests I can run with hp tuners to rule things out?
Help!
Im attaching my config file and the scan for anyone to take a quick look?
Car still drives great, but as soon as I delete that code it comes right back- Im stumped??
trans codes.zip
I'm terrible at electrical diagnosis
Is it still possible this is an electrical problem within the transmission? Can I use Hp tuners to begin ruling out possible causes for the clutch not being applied?
I also found this article which is basically a diagnosis tree- unfortunately I don't have any of the tools it asks for (all electrical) but can hp tuners substitute a lot of the diagnostic devices being used becasue it can trigger solenoids etc?
Here is the article: http://www.hotrodlane.cc/New%20LS%20...%205.7%20L.htm
Is there anything else that it could be? pcm or wiring from the pcm to the trans? could the issue be within the torque converter? or would that throw additional codes?
It could be wiring from the PCM to the trans, but test the two TCC related solenoids first.
It is electrical - so not likely a problem with the converter.
