Help needed 4l60e converter
Old May 26, 2014 | 11:34 PM
95FbFormula's Avatar
Default Help needed 4l60e converter
So to start its a 2000 TA 4l60e and an 03 5.3 converter is stock ls1 replacement while I am installing I can only get 2 good clicks of the converter after that I can only spin the converter about 180 degrees before it feels like it's engaging the trans so I checked my measurement and had a little over 1 inch from the the face of the bellhousing to the converter tabs I installed the trans but once it's all tight I can't even budge the converter this engine has no accesories on it or plugs in so I can turn it over fairly easy by hand before I installed the trans can anyone tell my what I may be missing or if I have a problem since I can't fully rotate the converter once I have it set in the trans
