4L80E tc question
Old Jul 5, 2014 | 09:50 AM
M.BOZZ's Avatar
Default 4L80E tc question
I'm replacing my th400 with a 4l80e in my 96 mustang. Will be going to 4:10 gears, my question is what would be a good stall speed tc for it ? The car weighs around 3100lbs and a lq4 stroker. I do go to the track sometimes and not really a dd. I have no experience with a/t so please help, thanks
Old Jul 5, 2014 | 11:54 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
I'd recommend contacting Yank and CircleD. They're both very helpful !
Old Jul 5, 2014 | 07:59 PM
Circle-D_Brian's Avatar
Assuming the car is N/A, I would suggest a 245mm converter in something like a 3600-4000 stall. This will be a good mix of performance and drivability. You can fill out the Ask Chris form in my signature with all the motor specs and intended usage info, and we can get the best converter for your swapped Stang.
-Brian
Old Jul 5, 2014 | 09:16 PM
M.BOZZ's Avatar
-Brian
Thanks Brain will do
