I know! Another 4l80 question...
I know I know I know. This is something that has been beating the forums for a while. I've got a 4l80e 6 bolt pattern stall converter along with a tci flexplate to match. The snout of the converter was extended to accommodate for the crank. My problem is the bolts are banging around on the flexplate. I had to get some longer bolts to reach the flexplate. And when I say the holes on the flexplate are huge, they are huge. Mind you, the bolt holes on the converter are also for standard bolts.
The bolts are slapping around in the flexplate, needless to say. Is there an alternative flexplate that I could use for this application other than the TCI?
