4l60e rebuild question
It sounds like your input drum is not fully seated; it is critical that it have some end play; .015 to .030 is the spec and I try to keep it on the low side. The selective washer will set the final end play.
I check end play with a partially assembled input drum, before installing the 3/4 clutch. You also do not need to install the reverse drum to check/set end play. This makes it trivial to install the input drum, bolt in the pump and check the end play; if necessary change the selective washer and re-check.
When fully seated and fully assembled, the top of the reverse drum will be a bit below the case lip for the pump and look like this:
You need to determine if everthing is properly seated, set the end play with the selective washer and the output shaft end play should take care of itself. If you decide that the output shaft has quite a bit more end play than the input shaft, Sonnax makes an output shaft washer/shim set to correct it, but I doubt that is often needed and would be a lot of extra work.
I "think" when fully assembled the output shaft will touch that torrington bearing when the output shaft and input shaft are pushing together. I will be swinging by local trans shop this morning and will ask.
CORRECTION My local trans mechanic did not think the output shaft would touch that torrington bearing. He explained that the input drum's movement into the trans is limited when the sun gear (attached to the sprag)bottoms out in the outer planetary. The selective washer then determines how far the input drum can move out, which is then the total end play.
Generally when you can install the clip on the output shaft, everything up to the outer planetary is spaced correctly.
Have you experimented with different selective washers to confirm you can get input shaft end play with the correct washer?
Sorry for my incorrect statement in the earlier post. I don't fully assemble a trans on a regular basis and therefore go partly by memory. I keep a disassembled 4L60E in my basement so that I can research details to answer questions here. Therefore I assembled the relevant parts outside of the case today. The torrington bearing in the input drum is called the "sun gear" bearing and indeed the input sun gear (snapped into the forward sprag) runs on this bearing. The end of the output shaft tappers to a smaller diameter and runs inside the bearing without touching it. The end of the input shaft does not touch the input drum and therefore has end play completely independent of the input shaft.
While the input shaft end play spec is .015 to .030, my local trans builder said that as little as .010 is fine, especially because it increases by a few thousands during early operation. I build a few at .012 and they have survived hard use. So, of all the end play you have is from the .015 gasket, that should be plenty.
