Help identifying what is inside this powerglide
Old Sep 4, 2014 | 01:55 PM
hawkmoon77's Avatar
Default Help identifying what is inside this powerglide
Hi everyone.
I was hoping someone could identify what is going on in my powerglide. I am attaching a picture set. I went to change out the transmission gasket and filter, and found what appears to be a solenoid inside the pan.
If you look at "A" in the pictures, you'll see the part in question. I traced the non-grounded wire and found it had been cut, and so it doesn't seem like it would be operational.
You'll also notice a solenoid "B" which is the transbrake solenoid that is connected to the shifter button.
Can anyone help me explain what solenoid "A" is about?
Thanks very much.
Attached Thumbnails Help identifying what is inside this powerglide-10.jpg   Help identifying what is inside this powerglide-11.jpg   Help identifying what is inside this powerglide-12.jpg
