Question about 4L60e and issues regarding
and it majorly sucks, because i have 4.10 gears. I was wondering if the 4L60e would solve this problem, making it cruise around 2500 rpm since the od gear is alot lower than 1:1. Second, how the hell does the tranny knows when am I OD, do i switch it, or the computer does that? And what is my best option, to lower my rpms. P.S. Rx7 diffs has barely any options to lower gear ratio.
Thank you guys for looking at my post!
Frankly I doubt you are at 6000 rpm at 60 mph unless you have 12" wheels.
Here are two calculator for determining RPM based on tire size, rear ratio and trans ratios:
http://www.wallaceracing.com/gear-speed.php
http://www.f-body.org/gears/
(Use the top left drop-down menu to select "1998 F-body A4" to have it fill in the 4L60E gear ratios.
The computer selects 4th gear like any other gear.
