what is the stall on a stock converter
Old May 25, 2004 | 09:26 PM
GM's Avatar
GM
Default what is the stall on a stock converter
i have an 02 z28 with the 323 gears . what is the stall speed of the stock converter ?
Old May 25, 2004 | 09:30 PM
blkZ28spt's Avatar
I think that stock converter stalls at like 1600-1700rpm with an STR of about 1.6. God I hate the way the barf icon looks, it's disgusting.......
Almost as disgusting as some of what they did to keep the LS1 F-bods behind the corvette and emissions legal
Old May 26, 2004 | 07:47 PM
DeepBlueZ's Avatar
1800-1900 rpm on LS1, 1600-1700 rpm on LT1, 1.6 STR.
Old May 26, 2004 | 08:30 PM
ActionJack's Avatar
I was told to put the car in 2nd (A4) and break hard and give it gas until the rpm hangs. When I did it I had it stop at 2000 rpm. That meant I have a 2000 stall.
BS? Who knows.... If someone can confirm the stall for a stock 01' ws6 as 2000 then it works. But if you try it have room in front of you so you do not hit a wall.
Old May 27, 2004 | 09:10 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
For a LS1, it is 1850 1.6 STR., 12" diameter (not exactly a stellar unit)
SteveC
