Flexplate and hub adapter confusion.
I am trying to mate Lq4 engine with th400 gearbox.
being stupid and straight on guy I just bought a SFI flexplate for SBC with 168T count. Guess what? It does not fit.
Did some search afterwards and I fount that SBC crank flange bolt patter, or PCD changed, when they changed two piece seal to one piece seal design. Two piece seal seal crank flange has wider PCD then one piece.
Does anybody know if one piece crank bolt pattern is the same as LSX? Refering to LSX I meen ls1-ls6.
My goal is to buy decent quality stamped SFI flexplate with 168T ring on it. I still going need to make an hub adapter/crankspacer for TH400 converter. Since I am running midplate for engine transmission mount.
Chris
For the mid plate you will need to get spacers for the converter and depending on the converter setup an even longer pilot extension.
Chris
