Vibration after th400 swap
Moser 9in rear end
Coan th400
UMI th400 cross member for 4th gen f-body
solid th400 transmission mount from jegs
new custom driveshaft (is correct length, has good u-joints, and the pinion angle is set correctly)
Umi tunnel mount torque arm (Spaced 1/2 inch down to allow clearance between driveshaft loop and driveshaft. torque arm was adjusted so pinion angle is correct)
umi torque arm mount & driveshaft loop
poly motor mounts
I did not just immediately post this thread. I have done endless searches and have been under the car trying everything i can think of to get rid of this vibration. The u-joints are good and the pinion angle is set correctly. I'm pretty much convinced at this point that this is not a drivetrain geometry issue. As far as i'm concerned there is no wrong answer. If you have any idea as to what it might be please post it. I am open to anything and any help is greatly appreciated.
Common to see when transmissions are swapped.
You have to check your trans angle and the pinion angle.
What is the pinion angle and how are you checking it?
Trans angle?
