Rpm drop 1-2 shift 4l80
Old Dec 16, 2014 | 09:11 PM
JDMC5's Avatar
Default Rpm drop 1-2 shift 4l80
I'm in the middle of my 4L80 swap and I'm wondering what the rpm drop will be after the 1-2 shift.
Mods are in signature ~400-420 wheel hp LS1. I'm running a 245mm (9.5") converter which should stall about 3600-4000 rpm. I'm shifting at 6600 rpm. According to my estimation I should see roughly 4400-4500 rpm. What do you guys think? Also, what are you seeing after your shifts?
Old Dec 16, 2014 | 11:16 PM
Jake's Performance's Avatar
Sounds about right but the converter has a big effect.
Old Dec 17, 2014 | 07:17 AM
JDMC5's Avatar
Effect on rpm drop?
I've seen people with a similar setup to mine only drop to 5000 rpm, is this possible too?
Old Dec 17, 2014 | 09:21 AM
Yes,
The converter effects the rpm drop.
Old Dec 17, 2014 | 11:08 AM
JDMC5's Avatar
Yes I realize this. I was hoping you could tell me more specifics about how stall rating isn't the only factor on what determines shift recovery.
Or maybe some people could comment on prior experience with 3600-4000 stalls in a 4l80
Old Dec 17, 2014 | 11:49 AM
Converter build can affect the shift recovery. Stator selection, internal clearances, and other factors can affect it.
You can have a similar stall speed but have a converter that pulls the engine down more above the stall speed.
Old Dec 17, 2014 | 12:55 PM
mrvedit's Avatar
Moderator
Its much more than just the advertised stall speed which will determine the-post shift RPM. One factor is the elusive "STR". I'm barely a converter neophyte, but I would expect a high STR converter to have a lower RPM after a shift than a lower STR converter.
This thread might help you understand the many variables:
https://ls1tech.com/forums/automatic...str-guide.html
Old Dec 17, 2014 | 02:48 PM
JDMC5's Avatar
Thanks, good info.I will try to dig up those numbers.
Irregardless it should be in the 4300-5000 rpm range which I'm perfectly fine with.
Old Dec 23, 2014 | 11:10 PM
kinglt-1's Avatar
I have a FTI 3800 with a 2.1 str...my rpm only drops to 5000rpm on a 6200 shift.
Old Feb 2, 2015 | 04:11 PM
JDMC5's Avatar
yea a friend of mine has a yank 4000 and it drops to 5400 on the 2-3 shift with a 6600 shift point, 4L60. IDK what the 1-2 is it can't get traction yet. I hope mine is close, I love that stall.
