4l80e rebuild log, input welcome
This is me walking my manx next to my 2010 ISF with a 420HP 5 liter engine. Now decide if you really want to help me!
I'm starting from the output shaft forward since my donor trans is from a 2WD truck and my 2002 Yukon is 4x4.
Oh, the truck. Wifey and I are going storm chasing late this summer and I simply don't trust the 4l60e in it with 145k miles. I've rebuilt everything but the engine and trans at this point. I really need to ensure we can get out of the way of a tornado!
Crooked:
All the way seated. How does the bearing look? I see some stress points and light scratches. This is a hydraulic bearing correct? Should I trust it?
Output carrier assembly that rides in the bearing. Not perfectly smooth but should be OK I hope.
Thrust washer. Light scratches. Thoughts?
For those with older trans using the Sonnax case bushing. Some older output shafts with the oil holes will have the holes nearly fully covered up. You'll need to grind a valley in the hole to increase fluid output (Sonnax has instructions on this). Mine seems open enough.
Oh and planetary carriers measured within the .009'' to .024'' acceptable range.
More to come as time permits.
