Running two trans coolers
Old Jan 11, 2015 | 11:42 AM
Shownomercy's Avatar
Man-Crush Warning
Default Running two trans coolers
Parallel or series?
I have a Jake's 80e and have a electric fan cooler under the car, and a big stacked tube cooler up front, they currently are plumbed in parallel. The trans lines split to feed each one then combine again to return to trans.
Is this a bad setup, or should I be fine? Lines are all 6an stuff.
Old Jan 11, 2015 | 02:24 PM
01ssreda4's Avatar
I would keep them as is.
Old Jan 15, 2015 | 05:02 PM
HomeSchool's Avatar
If it ain't broke, don't fix it. However, if you start having issues with this setup, change it up. And leave us a detailed post in the appropriate section. I ****ing love this website when it comes to write ups.
