4L60e shifter linkage
Old Feb 8, 2015 | 06:45 PM
WTR's camaro's Avatar
Default 4L60e shifter linkage
recently did a stall swap on my 02 camaro. somehow the linkage managed to get pulled down when we dropped the trans. anyone one know if i can correct this myself by pulling the linkage back up? also i somehow hit the shifter inside the trans and the car is in a forward gear. anyone know if can correct this?
and iknow noobie stuff...but hey got to learn somehow
Old Feb 8, 2015 | 08:41 PM
bbond105's Avatar
If the outside cable housing was not pulled apart and the cable itself is not broken it should be fine and just needs adjusting. I like to adjust my cables with the shifter in natural.
To adjust unhood the cable from the lever on the side of the trans, twist this lever to the front of the car until it stops, (this should be park, with rear wheels off the ground you can turn the drive shaft to verify that it locks into park), now twist the lever back to the rear of the car 2 clicks, (should be natural). Now inside the car place the shifter in natural. Now back under the car see if the cable will hook up to the lever on the trans without moving the lever or cable. If not push the cable adjuster lock up, this is just rear of where the cable pushes into the cable bracket that is bolted to the trans pan. Now hook the cable end to the trans lever without moving the lever and push the cable adjuster lock down to lock the cable into place and move the shifter through all positions to verify the adjustment is correct.
Old Feb 8, 2015 | 09:37 PM
thanks as soon as im off work tomorrow i will give it a run.
Thanks Walker
Old Feb 10, 2015 | 04:18 PM
well i went up under the car and im pretty sure the cable is done. cause i cant move into any gear.
Old Feb 10, 2015 | 06:10 PM
bbond105's Avatar
Will the shifter move with the cable unhooked from the trans?
Old Feb 10, 2015 | 07:08 PM
srry shifter itself is good. but the cable is done. from inside the car i can pull it out of park down through all the gears but cant push it back up.
