4l60 - convert 4wd to 2wd
A trans mechanic could theoretically swap from the 4wd to the 2wd output shaft in about an hour. However assuming the trans has many miles on it, in reality the teflon seals will likely tear, the band will be worn, the reverse drum too pitted for a new band, the 3/4 clutch on its last legs, etc. In other words, it is a very slippery slope to a complete rebuild.
Also remember that pre-'98 and V6 transmissions do not bolt up directly to LS engines and vice versa.
Also remember that '94 and '95 models only work with PCMs from that exact same year.
Why not post what year trans you are considering buying and what year vehicle and engine type you have. If a custom car, what year is the PCM.
I figured if it had to be torn down, it might as well get rebuilt.
The answers to the questions in my previous post will let us determine whether the trans is even compatible.
